7
Does ALM mean "Adaptive logic module"?
www.altera.com/literature/ds/ds_nios2_perf.pdf‎ Jul 1, 2013 -
One ALUT is equivalent to about 1.25 LEs.
Does LE mean logic element and ALUT means adaptive look-up table?
http://quartushelp.altera.com/10.0/mergedProjects/reference/glossary/def_alm.htm
The Adaptive Logic Module (ALM) is the basic building block of supported device families and is designed to maximize performance and resource usage. Each ALM, composed of two Adaptive Look-Up Tables (ALUT) ...
LE has meant "logic element" for many years, although what defines a logic element is not entirely static, in Altera-land is usually means a 4-input look-up table (sometimes called a 4-LUT) + a d-type flipflop (DFF).
  • \$\begingroup\$ Do you have a reference for the Altera definition of the logic element? \$\endgroup\$
    – Randomblue
    Oct 21, 2013 at 18:09
  • \$\begingroup\$ Not a good one... This is as close as I got, but it looks out of date (Xilinx's devices stop at Spartan 2 in the table!): altera.co.uk/cgi-bin/device_compare.pl - it says Altera's and Xilinx's basic building block is a 4-input look-up table (LUT), a flip-flop and some additional circuitry that Altera calls a logic element (LE) and Xilinx calls a logic cell (LC). \$\endgroup\$ Oct 22, 2013 at 15:22
