I need to know when the 14 MSB bits from the address bus of a z80 CPU are high. To do so my first idea is to use 4 74LS08 ICs (TTL AND gates) reading those lines but I don't know the maximum amount of current that can be drained from the CPU.
The 74LS08 has a maximum input current is of 0.1mA hence 1.4mA from the z80 but I cannot find the maximum z80 ratings on the zilog datasheet. The z80 datasheet mentions a TTL chip select decoder connected to the address bus but no mention of the IC ratings are given.
so, can I connect 14 TTL inputs to the z80 address bus without overloading the z80 outputs?
z80 datasheet
74LS08 datasheet
Clarification
One TTL input per address line, not 14 TTL inputs per address line.
