I'm looking for a small kind of pushbutton that I'm not even sure exists.
I want it to have these properties:
Width: 7mm (Will compromise for 5mm-10mm)
Travel distance of 2mm (Will compromise for 0.5mm-2.5mm)
Actuation force: 40g (Will compromise for 40g-45g)
I've emailed a bunch of suppliers but none of them have a button like that.
Is anyone aware of a button like that?
Is there anywhere where I could post a cash bounty for someone to find a button like that for me?
You can take any button and add an appropriate spring assembly and build something that suites your needs.
An excellent selection of buttons are here: http://mouser.com
A primer on selecting springs can be found here: http://www.centuryspring.com/pdfs/12-228compression.pdf
  • \$\begingroup\$ I should mention that you need to factor in the push force required for the button as it will be added to the force of the spring. \$\endgroup\$ – Albert Sep 28 '13 at 4:17
Have a look in the Panasonic catalog; I found EVQ-PH recently, something similar would suit you: http://www.panasonic.com/industrial/components/pdf/linecard_switch.pdf
  • \$\begingroup\$ Actuation is way too high. \$\endgroup\$ – Ram Rachum Sep 9 '13 at 22:48
I sell these small (box is 5 x 4 x 8 mm) switches:
But these are surplus (not recommended for production). I got them from electronic goldmine, but they are out of stock there. No clue how they would be called.
  • \$\begingroup\$ Since (a) I have no idea what their actuation force is and (b) I can't use them in production, I think I'll pass. Thanks! \$\endgroup\$ – Ram Rachum Sep 9 '13 at 22:48
  • \$\begingroup\$ a) neither have I, but it is very low compared to all other buttons I have. b) indeed, but the picture might give you a hint what to look for (alas, there is no code or manufacturer mark on the black box). \$\endgroup\$ – Wouter van Ooijen Sep 9 '13 at 22:51
