Is there a framework for circuits simulation that I can use through easy APIs? and return me an array of results for each component?
I want to build an android based simulator, so a java framework would be perfect, is there any advice?
  • \$\begingroup\$ One possibility would be to make a wrapper for the good old SPICE and parse its output. If you really want Java, you could take a look at Falstad Circuit Simulator, but I'm not sure of its license and how easy it would be to call it externally. I think they used it for iCircuit. \$\endgroup\$ – AndrejaKo Sep 10 '13 at 9:47
  • \$\begingroup\$ Would it be possible to wrap SPICE and call it in android? has any one done this before? \$\endgroup\$ – simo Sep 10 '13 at 10:18
  • \$\begingroup\$ I don't see why not. You'll have to compile SPICE for ARM (you may have to experiment a bit with compiler settings to get the widest amount of supported processors) and then call it from your GUI, which isn't all that complicated. What would be a bit complex is to write a program that will actually generate scripts for SPICE and then show results in a nice way. \$\endgroup\$ – AndrejaKo Sep 10 '13 at 10:25
  • \$\begingroup\$ AndrejaKo, would you be interested to accomplish it as a freelance project? (the SPICE calling side, I will do my own gui to show results) I've searched for your email, but I couldn't find it :) \$\endgroup\$ – simo Sep 10 '13 at 12:14
  • \$\begingroup\$ Sorry, but I'll have to refuse. Your offer does sound extremely tempting, but I can't accept it for several reasons. First: I don't have any experience with mobile phone application development in general and even less with Android in particular (I'm still using a Symbian phone), second I don't have much experience making SPICE net-lists, since I've always used it through wrappers. \$\endgroup\$ – AndrejaKo Sep 10 '13 at 12:29
protected by W5VO Sep 10 '13 at 16:01
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
