9
Inspired by this blog post, I decided to put together a simple ring oscillator that transitions through 3 different LEDs. My schematic is almost identical the one in the blog post except that I used 2N2222 NPN transistors instead of MOSFETs. However, the LEDs are not oscillating. All three slowly light up and then stay on. What am I doing wrong?
My schematic:
Picture:
    \$\begingroup\$ BJTs are current-operated devices, while MOSFETs are voltage-operated. In this case, the difference is quite significant. \$\endgroup\$ – Dave Tweed Sep 11 '13 at 3:14
  • 7
    \$\begingroup\$ The LEDs in your diagram are backwards. \$\endgroup\$ – travisbartley Sep 11 '13 at 3:48
11
Page 31 in this document shows a similar circuit.
Apart from the slightly different architecture three interesting aspects:
  1. C4 creates a start condition by introducing an imbalance in the ring;
  2. BJT's instead of MOSFET's (MOSFET's in the circuit from the blog you refer to);
  3. Much lower values for the resistors, BJT's are current driven rather than voltage driven like MOSFET's are.
In my experience the circuit refuses to run on 6V, but 9-12V worked fine.
    \$\begingroup\$ I ran this on the circuitlab simulator and it is working for 9V and the default components. Ring oscillator cycle time is about 0.6 s. \$\endgroup\$ – travisbartley Sep 11 '13 at 6:03
8
Here's the circuit that inspired you: -
This circuit works because it uses mosfets.
Replacing the mosfet with a BJT isn't going to work. For a start, using 1Mohm for the base resistor of a BJT means the maximum current into the base (from 6V) is 6 micro-amps. The current-gain of each BJT might be 200 and this means about 1mA drive to the LEDs and hardly enough to make them bright.
But, worst of all, due to only 1mA in the collector, the collector voltage will be at about 4V and not likely to be lower. This means the actual base current is only about 4uA and this means probably about 4.5V (ish) on the collectors and somewhat less than 1mA thru each LED.
All the collectors will be like this - and in turn, they are partially turning on the BJT that is following - all the LEDs will be dimly lit and no ring oscillation I'm afraid.
The mosfets work because their gates are, to a slow speed signal, an open circuit and the caps on the gates can fully charge without being limited by the forward conduction of a BJT base-emitter junction. And, because there are a ring of three devices, the mosfet will continue to turn fully-on properly illuminating its LED and properly discharging the subsequent RC network attached to it's drain thus turning off the mosfet after it.
Here is a better circuit that you can try. Connect the ground leads to the negative terminal of a DC power supply and the VCC lead to the positive terminal. When the DC Voltage(potential difference) between the ground and the VCC is >= +10V it starts up and oscillates continuously until the power supply is interrupted. One design note: The schematic was constructed and tested using NI MULTISIM 14 but for the physical circuit I used NTE101 Germanium NPN transistors instead of the 2N3904 silicon NPN transistors. Try connecting the LEDs in parallel to the Oscillator output lead on the right of the schematic.
