I want to make a double side PCB design in ARES ( I have the desing in ISIS and I know how to do it), but for some specifics devices (Integrtate Circuit Socekts DIL16 and DIL28) I don't how to force ARES auto-rute to make these connections on the bottom side layer of the PCB. I have try to eliminate the top layer of each pin of every socket but when I call the auto-route I get a lot of errors/warnings from the program, becouse ARES calculate many routes on the top side over the pin holes of the sockets (see picture area into the green line ). Any idea how to config ARES for the right calculation?
\$\begingroup\$ These aren't many connections. I suggest you route it manually. Will be quicker than trying to configure the software. \$\endgroup\$– Gustavo LitovskySep 11, 2013 at 18:15
\$\begingroup\$ The picture is only an example of one socket, I have six sockets with the same problem, one of them a DIL28 and the PCB board is 6"x 4" size. I would like to expect the 80% of the works will be done with the auto-route rutine, and after this to made a manually adjustment if necessary. But at the moment ARES with my actual configuration doesn't help me with this. \$\endgroup\$– AlfSep 12, 2013 at 16:18
\$\begingroup\$ Off topic, but I cannot see any bypass capacitors near by your ICs. If you need them, don't forget to manually place them. \$\endgroup\$– abdullah kahramanNov 28, 2013 at 13:55
1 Answer
You can do this in 5 steps: (my version is 7.9 sp1)
Technology >> Design rule manager a new window will appear >> Net classe tab >> net class >> power pair 1 Hoz and Ver make them bottom Copper. and for net class Signal also Hoz and Ver will be Bottom Copper.
make a suitable board Edge
Track mode (The line that you will use) Edit it as you want
Technology >> Layer usage >> uncheck all inner and mech layers(Don't use any of them)
Technology >> Layer Pairs >> make all Bottom Copper
