In 8051, there are 128 bytes of RAM. Of which, 32 are set aside for registers in the form of banks, 8 registers to each bank. Each bank is addressed from say 00 to 07, 08 to 0F, etc, that is, occupying 8 bits each, with each but corresponding to a register, thus 8 registers in each bank.
How can this be possible, when the registers themselves occupy 8 bits? Won't each bank occupy 8*8 = 64 bits instead of 8?
Each address holds 8 bits. 32 addresses are set aside as registers, 8 bits each. Each register bank has 8 registers in it. Each register bank is 64 bits/8 bytes. 96 addresses are as RAM. 96+32 = 128 Bytes total. It's just that the first 32 bytes are registers rather than RAM. I think you may be getting bits mixed up with bytes.
  • \$\begingroup\$ Oh ho, each register occupies 1 byte, so 8 registers mean 8 bytes, or 1 bank. That's dumb of me..Thanks! \$\endgroup\$ – SexyBeast Sep 11 '13 at 23:08
  • \$\begingroup\$ Out of curiosity, do you know if any 8051-architecture chips actually implement the first 32 bytes as registers different from the remaining 96/224, or does "ADD Rn" simply do a normal RAM read from address "000bbnnn"? \$\endgroup\$ – supercat Sep 12 '13 at 15:50
