I want to use a ATmega (168 or 328) with a 3V button cell. Which isn't the problem but at the moment I think about how to make it pogrammable in the target board. The board will have some peripheral devices like leds which can't operatet at a higher voltage.
So can a normal ISP programmer or even a USB to TTL adapter be used to programm this 3V system?
You can find USB to TTL adaptors that are 3.3v compliant (Use your power source not the one provided by the adaptor)
and some ISP programmers will have a jumper to choose the voltage
