I'm trying to get a better handle on the derivation where load-line analysis comes from. This is because I have a system that essentially has two different loads operating on a single diode and I'd like to see the operating point for this device by using my own load-line analysis (because this is computationally faster than doing it the other way). The only way I know how to do it right now is to explicitly calculate the J-V curve for the diode as it is affected by one of the loads and then do a load-line analysis with the other curve, unfortunately for my system calculating the J-V curve with a particular load is very computationally intensive. Might somebody be able to point me to a detailed reference or even have any idea of how to go about doing this?
/// Rephrasing question
In a field that interests me, the goal is to collect sunlight and then drive electrochemical reactions. Suppose we are interested in what is called water splitting, that is taking H2O and making H2 and 1/2 O2 by applying an electrical bias across two electrodes immersed in a solution of water that has a relatively high conductance due to added salts. Typically we achieve this using what is called a potentiostat, a device we can control and tell to apply a particular bias across the two electrodes and then measures the resulting current. So we end up with J (current density) and V (voltage) curves.
Instead having all the power come from the potentiostat, we can replace one (or more) of the electrodes with semiconductors. Given the right matching between the reaction of interest, say water splitting, and the band gap of our semiconductor, we might be able to drive the reaction when we properly balance our system. Unfortunately, even when we apply the correct thermodynamic required potential across the two electrodes we will not always see much, if any current, because the chemical reactions tend to have kinetic factors in addition to thermodynamic factors determining their resulting rates for a given voltage applied across.
The overall water splitting reaction is actually made up of two-half reactions. One is the anodic process where H_2O -> 1/2 O_2 + 2H^+ + 2e^- and the other is the cathodic process where 2H^+ + 2e^- -> H_2. The current-voltage behavior at metal electrodes is often described by what is called the Butler-Volmer equation. There are empirical factors in this non-linear equation that can be determined and successfully used to model the effect of various different materials trying to catalyze a given reaction.
Say for our water splitting cell we are evaluating different photoanodes. So we're taking diodes, immersing them in solutions, and electrically completing the circuit by having a metal electrode do the corresponding reaction. Say our photoanode is oxizding water to oxygen, then our metal electrode is reducing oxygen to water or water to hydrogen gas.
This is from the literature, "Solar Water Splitting Cells" by Michael G. Walter
We'll end up with J-V curves like those shown in Figure 9. (From a paper in the literature.) The dotted lines show the J-V curves on metal electrodes and the solid lines show those same materials affecting diodes that are carrying out the same reaction. One can get at these curves by taking the diode equation and ending up with pairs of (Voltage, Current) points for our J-V curves. One can take each current and solve the Butler-Volmer equation for the overpotential required (this is computationally intensive unless assumptions I do not want to make are done). Then one ends up with a Overpotential corresponding to each Voltage (the overpotential is voltage dependent), so one can now plot (Voltage + Overpotential, Current) and you obtain the resulting curves which may be either "good" or "bad". This overpotential is the extra required potential required to overcome the kinetic limitations of the reaction of interest.
Now one can make these curves for both the photoanode and photocathode. What has been described in the literature is shown in the next figure,
This represents what would happen if one were to build a device consisting of both this particular photoanode and this particular photocathode. The resulting J-V curves are put on a common potential scale and where they intersect is considered the operating point for the device. Unless I am mistaken, this is in essence a load-line analysis?
It might be the case that this circuit represents a simplified picture of the overall process:
(I don't actually know enough about circuits to know if I am completely off base here.) Ultimately what I'd like to do, as they do for this circuit, is determine the efficiency of the device, i.e., how able a given combination of devices is able to convert solar flux into chemical products of interest.
Now where I don't know the answer is how to use a load-line analysis on this equivalent circuit:
(the values for resistance or capacitance are arbitrary in both equivalent circuits.) In this case we have one photodiode carrying out both reactions and the device's performance will be affected by the kinetics of both reactions. In the case of Figure 3, they have two separate photodiodes and their characteristic curves they overlap to find the operating point for their device. I have three plots, one of the photodiode (a J-V curve), and two J-V curves corresponding to each half-reaction. I'd really like to be able to take some combination of these and find a graphical solution rather than numerically attacking this problem.
    \$\begingroup\$ Your question needs a great deal of clarification. Can you show us a schematic of what sort of circuit you are analyzing? A load-line analysis can be used in a variety of situations. Why are you worried about current density instead of just current? How can the load affect the diode's intrinsic I/V characteristics? What do you mean when you refer to "the other curve"? \$\endgroup\$
    – Joe Hass
    Sep 16 '13 at 22:30
  • \$\begingroup\$ This isn't a textbook circuit and I'm not an electrical engineer. The current density matters when actually building diodes, i.e., I can't cut every piece of my wafer to be the same size because I do this by hand and I want to draw comparisons between measurements I take. There is no schematic for this circuit. I have a single semiconductor driving two chemical reactions and it does this by work. Both chemical reactions require overpotentials that will affect the operating point of the device. Would you like to me show you an example where I've seen it applied in the literature? \$\endgroup\$ Sep 16 '13 at 23:23
  • \$\begingroup\$ @sciencenewbie if it isn't a "textbook circuit" then that's all the more reason to provide a schematic --- it's how we communicate the relevant details so that others can understand our work. If there isn't a schematic already drawn, you can draw one to help us understand what you are asking. \$\endgroup\$
    – The Photon
    Sep 16 '13 at 23:49
  • \$\begingroup\$ @sciencenewbie I think you've made my point. Your situation is quite unique and the answers that you are likely to get may not be very helpful. Please help us help you by telling us as much as you can about your application, and an example from the literature would be great. It's fine that you are not an engineer but, for better or worse, many of us here are engineers. \$\endgroup\$
    – Joe Hass
    Sep 17 '13 at 0:10
  • \$\begingroup\$ @JoeHass I've tried my best to draw the equivalent circuits... I'm not an expert and may have drawn them incorrectly. But I did show an example from the literature where they are, from what I can tell, essentially doing a load-line analysis. Let me know if I should elaborate further. \$\endgroup\$ Sep 17 '13 at 1:59
OK, with the added information, there's a lot more to say about this problem.
First, a load-line analysis is not going to deal with the dynamic aspects of your problem. All it can do is solve two equations with a common independent variable. If you add time as a second independent variable you're not going to be able to solve the problem this way. Normally what you'd do is use load lines to solve the steady state condition after all dynamic effects have decayed to insignificance.
Second, you say that calculating the values on your curve "is computationally intensive unless assumptions I do not want to make are done". The load line solution will only be as accurate as your plot of the curve. And it will further be only as accurate as you are able to discern the coordinates when viewing the plot.
If you're okay with the accuracy of a load line solution, you could consider doing an automated solution this way: Choose 10 or 20 x-values for your curves. Make a spline interpolant for your curves using the carefully calculated values at those 10 or so points. Now solve for the intersection of the two spline, which will be very quickly calculated. This will probably be no more accurate than the available approximating formulas for your curves, but it will probably be as accurate or more than the load line method.
If you really want a solution that has the full accuracy of your complex equations, you could use the spline method to find an approximate solution and then use a more exact method to find the "true" solution. For example, the bisection method is fairly simple to code and doesn't require being able to calculate the derivative of your function. And it can find a solution with accuracy \$\delta\$ in roughly \$-\log_2\delta\$ steps. It does help to have two starting points that straddle a solution, but that should be easy to find using the initial spline solution.
Load line analysis is just a graphical way to approximately solve two simultaneous equations.
y = f1(x)
y = f2(x)
For example:
Here, the equations are
\$ I = \frac{1}{R}\left(V_{DD} - V_D\right)\$
\$ I = I_0 \left( \exp\left(V_D / V_T \right) - 1\right)\$,
where I0, R, VT, and VDD are givens of the problem (characteristics of the voltage source, resistor, and diode).
Where the two lines cross is a solution to the system of (two) equations. If the lines only cross at one point, then there's only one combination of (x, y) that solves both equations. There's no real "derivation" of the method beyond that fact.
