Can anyone find a data sheet for what I think is a relay? It has the code cr730-a-24, 7.5A 250V on the case and I've found this picture:
Are the three circles, 3 coils in parallel? How does this circuit relate to the pin-out? In what sequence do the normally open, relay contacts close?
It appears to be a relay used in PIR lamps.
source - P29
The diagram appears to be an application where a set of three lights can be switched on by any of three switches or relays. I would guess that PR1 and PR2 are two PIR detector units at separate locations and that wylacznik is a manual switch. I don't think you can deduce anything about the CR730-A-24 relay from that diagram.
  • \$\begingroup\$ Hi, but do you know the pinout of one relay? \$\endgroup\$
    – reggie
    Sep 18, 2013 at 18:44
  • \$\begingroup\$ @reggie, if you're still interested in this question determining a relay pinout is normally pretty trivial if you either have the relay or the board that requires one, but would be best as a new question. \$\endgroup\$
    – PeterJ
    Nov 17, 2013 at 12:14
