I'm actually trying to build a precise full wave rectifier. But after a first failed try, I though I would better be off break down things to analyse every part of the circuit.
So, I started building a half-wave rectifier...
and even at this point I'm seeing something I was not expected:
Precise half-wave rectification
So, has you might guess, the yellow wave-form is my Vin and the blue is my Vout (both channels are AC coupled).
Here's the difference when I change my scope settings to have both channels to DC coupled:
DC coupled
I was sincerely expecting to get something more like this:
expected
Currently I'm using 20k (1%) resistors, ahottky diodes (1N5818) and the TLC272ACP op-amp.
Any thoughts on what is going on? Why am I still getting a negative portion of the rectified wave form? I must have messed something up...
I've basically edited this post, because I realized that I've made a mistake on the circuit. As I'm using this circuit to power up an A/C appliance, I wanted to use the same power supply to power up the circuit. So basically I've connected a AC/AC transformer to drop-down voltage from 230 to 6V (or 12V), and then got the AC converted to DC through a bridge rectifier and later regulated to 5V.
The thing is, I noticed I was using "different grounds" in different parts of my circuit. I was giving ground passed through the voltage regulator to the op-amp and giving ground directly out of the bridge rectifier to the bias the CT sensor.
For some reason that is not clear to me, between the "regulated ground" and the ground output directly from the bridge rectifier there's a difference of 2.3mV.
Well, know after having this corrected I get this on the scope:
Same ground...
Once again, I was expecting a closer match in terms of Max voltage...
  • \$\begingroup\$ What does the circuit look like? \$\endgroup\$
    – jippie
    Sep 21, 2013 at 17:59
  • \$\begingroup\$ Check electronics.stackexchange.com/a/82619/8627 and electronics.stackexchange.com/questions/82615/… \$\endgroup\$
    – jippie
    Sep 21, 2013 at 18:00
  • 5
    \$\begingroup\$ I'm not familiar with your scope, but I suspect from the labels that your scope inputs are AC-coupled, which would account for the output waveform going negative. \$\endgroup\$ Sep 21, 2013 at 18:04
    \$\begingroup\$ @PeterBennett I just bought the Rigol 1052E, and I've never worked with an scope in my life, basically I read some tutorials but I'm not completely familiarized with it. So... do you mind explaining what exactly do you mean by your answer? (sorry... extreme noob here). \$\endgroup\$
    – cvicente
    Sep 21, 2013 at 18:21
    \$\begingroup\$ @cvicente: There should be a setting for each input channel to select AC coupling, DC coupling, or Ground. With AC coupling, there will be a capacitor inserted in series with the input to remove the DC component of the signal. DC coupling removes this capacitor. If your signal was a square wave going from 0V (ground) to +2V, DC coupling would show it correctly, but AC coupling would show it going from -1V to +1V. \$\endgroup\$ Sep 21, 2013 at 18:44
It looks like your output is only going about 4mV below ground. The input offset voltage for the TLC272 is up to 10mV so maybe you need to pick an opamp with a smaller offset. Seeing a schematic would be helpful, too.
  • \$\begingroup\$ The schematics is the one of a text-book precise half-wave rectifier \$\endgroup\$
    – cvicente
    Sep 21, 2013 at 18:03
    \$\begingroup\$ @cvicente linking to a text book circuit does not give values. I'm interested in the values you have chosen, what frequency you are inputting and what gain you have. Maybe you can post your exact circuit. \$\endgroup\$
    Sep 21, 2013 at 18:27
  • \$\begingroup\$ I've just edited my question to include the circuit diagram as requested. \$\endgroup\$
    – cvicente
    Sep 22, 2013 at 14:25
  • \$\begingroup\$ I've also corrected the OP-AMP... I forgot the ACP at the end, so it's TLC272ACP. \$\endgroup\$
    – cvicente
    Sep 22, 2013 at 14:32
  • \$\begingroup\$ I think Peter Bennett may have hit the nail on the head with his observation that the 'scope is ac coupled. It is critical that you fix that problem and let us know how it affects your waveforms. \$\endgroup\$
    – Joe Hass
    Sep 22, 2013 at 16:29
