-2
I have 1Kw supply of three phase in my home. I need a single output of all three phase and neutral.
E.g If I connect 1 equipment of 600watt 15 amp single phase, now I want equal load 200watt 5 amp on each phase. how I connect this equipment on three phase.
  • \$\begingroup\$ Why don't you have a power technician do it for you? I don't think it is reasonable for someone to bring you up to speed in a short answer for a task like this. \$\endgroup\$ – travisbartley Sep 24 '13 at 3:23
  • \$\begingroup\$ This question appears to be off-topic because it is not about electronics design. \$\endgroup\$ – JYelton Sep 24 '13 at 3:40
  • \$\begingroup\$ @JYelton: I wouldn't vote to close because the question is "off topic, not about electronics design". (See electronics.stackexchange.com/questions/83152/… for a popular question not about electronics design!) Rather I would VTC based on the poor quality of the question or possibly "too localised". \$\endgroup\$ – Li-aung Yip Sep 24 '13 at 5:44
There are two basic approaches to this.
You could do it electronically, by building a 3-phase power supply that provides DC power to a single-phase inverter.
The other approach is to use a rotary converter, which is basically a 3-phase motor and a single-phase generator integrated onto a common shaft.
  • 6
    \$\begingroup\$ Unless the OP is quite knowledgeable, he is more likely to die trying than to succeed. \$\endgroup\$ – travisbartley Sep 24 '13 at 3:57
    \$\begingroup\$ That's why I didn't get into specifics. Generic question gets generic answer. Both solutions are available commercially, so it isn't necessarily a DIY project. \$\endgroup\$ – Dave Tweed Sep 24 '13 at 4:32
  • \$\begingroup\$ its common problem in houses where load is not equal and they paying lots of money..if we sync 2 DG power in 1 output then y not sync 3 phase.. \$\endgroup\$ – Mayank Gehlot Oct 23 '13 at 16:06
