Hi while reading the datasheet for an ethernet controller chip, I came across the terms functional mode and test mode in relation to JTAG.
Can someone kindly explain these terms.
Functional Mode: The inner logic is connected to the externally visible pins; the device works as it is intended to. If a sample/preload instruction is issued via JTAG, it is possible to sample the current pin states.
Test Mode: The inner logic is disconnected from the pins and pins are driven/read by the boundary scan logic only. This is usually referred to as EXTEST.
I find the explanations from XJTAG very user friendly, so you might want to check those out: http://www.xjtag.com/support-jtag/jtag-technical-guide.php
