I'm trying to implement a clever way to do error correction of 4 bits with the classic 3 parity bit correction and such.
I'm constrained by the number of logic gates I can use, but I'm trying to implement the following logic expression
OUT = AB(~C) + A(~B)C + (~A)BC + ABC
I have access to A, B, C, ~A, ~B, ~C, (A + B), (A + B + C), ~(AB), ~(BC) from other parts of the circuit. I also have exactly one inverters and 4 NAND gates (2 inputs per gate) to spare. Is it possible to implement the above logic function?
(I am using ~ as logical NOT)
I've messed around with De Morgan and Karnaugh maps but they don't help much when it comes to gate-specific constraints like these.
UPDATE: I've freed up 1 extra inverter and 1 extra NAND, for a total of 2 inverters and 5 NANDs.
  • \$\begingroup\$ How many inputs on each of your NAND gates? It looks like four 3-input gates would do nicely. \$\endgroup\$
    – Dave Tweed
    Commented Oct 1, 2013 at 18:51
  • \$\begingroup\$ 2 inputs on each NAND. but if it's worth anything I'll upvote an explanation using 4 3-input gates \$\endgroup\$
    – ejang
    Commented Oct 1, 2013 at 18:54
  • \$\begingroup\$ Note that the last term can be combined with any one of the other three. \$\endgroup\$
    – Dave Tweed
    Commented Oct 1, 2013 at 18:58
  • \$\begingroup\$ yep, the k-map reveals that. i've figured out how to free up 1 more NAND gate and 1 more inverter from the rest of my circuit, so I have access to 5 now \$\endgroup\$
    – ejang
    Commented Oct 1, 2013 at 19:18
I think this is a solution, after playing with the expression a bit.
Derivation:
$$ AB\overline{C} + A\overline{B}C + \overline{A}BC + ABC$$ $$ = AB(C+\overline{C}) + A\overline{B}C + \overline{A}BC $$ $$ = AB + A\overline{B}C + \overline{A}BC $$ $$ = AB + C\cdot(A\overline{B} + \overline{A}B) $$ $$ = \overline{\overline{AB} \cdot \overline{C\cdot (A\overline{B} + \overline{A}B)}} $$ $$ = \overline{\overline{AB} \cdot \overline{C\cdot (A+B)\cdot\overline{AB}}} $$ Turning the 3-input NAND into 2 2-input NANDs and an inverter: $$ = \overline{\overline{AB} \cdot \overline{C\cdot \overline{\overline{(A+B)\cdot\overline{AB}}}}} $$
    \$\begingroup\$ Great work. I love logic gate derivations. I'm seeing a therapist about it. \$\endgroup\$
    – scld
    Commented Oct 1, 2013 at 19:42
  • \$\begingroup\$ my favorite answer, for good explanation & clever use of my existing circuitry. thanks! \$\endgroup\$
    – ejang
    Commented Oct 1, 2013 at 19:46
Following up on @Dave Tweed, we can simplify the logical expression to
OUT = AB + BC + AC
Using DeMorgan's this again is equivalent to:
OUT = (AB)'' + (BC)'' + (AC)
OUT = ((AB)' (BC)')' + (AC)
This as it is, can easily be converted to a logic circuit that uses 2-input NAND gates
  • \$\begingroup\$ However, this uses 4 more gates than available. \$\endgroup\$
    – scld
    Commented Oct 1, 2013 at 19:15
  • \$\begingroup\$ new development, i actually have 5 gates now. this one uses 5 gates and i can use the inverter to spare. cheers! \$\endgroup\$
    – ejang
    Commented Oct 1, 2013 at 19:28
  • \$\begingroup\$ @ejang Good to hear! I actually made a few changes. So I got rid of 2 NAND gates and put in that inverter of yours. Now this design is one you can work with! \$\endgroup\$
    – Shabab
    Commented Oct 1, 2013 at 19:30
  • \$\begingroup\$ @ChrisL Sorry for not mentioning earlier: Thanks for the review. I wouldn't have gone and been able to crrect my previous errors otherwise. \$\endgroup\$
    – Shabab
    Commented Oct 1, 2013 at 19:31
    \$\begingroup\$ You can get rid of NAND1 and NAND2 because ~(AB) and ~(BC) already exist in "other parts of the circuit". \$\endgroup\$
    – Greg
    Commented Oct 1, 2013 at 19:35
