By looking at AD9850 DDS or other similar parts made by Analog Devices Company it is obvious that the output signal amplitude changes by frequency. This can be shown as x= pi* fout / fClock and amplitude changes by Sin[x]/x. By using this formula we should see an amplitude drop less that 20% between 1Hz to 50 MHz but this is not the case that happens. As I am driving this part, I see the amplitude is around 1 volt pk-pk at 10Hz and 10mV at 50 MHz. Is anything I am missing in these calculations?
    \$\begingroup\$ I don't think that plot is showing what you think... It is telling you how to calculate the frequency and amplitude of extra spurious frequencies that will be generated when operating at certain fundamental and reference clock rates. It is not telling you how the amplitude of the fundamental varies as you change the fundamental frequency. \$\endgroup\$ – Justin Oct 2 '13 at 14:34
    \$\begingroup\$ Yes, it is about aliased signals (images) and discusses about how to avoid them. But if we take the first part ( 0-100MHz),it is the fundamental frequency (0-50MHz) and the first image (50-fClock). \$\endgroup\$ – Aug Oct 2 '13 at 14:37
    \$\begingroup\$ My guess is that you have too much capacitance (or a lower capacitance with a high series resistance) on the output. At 10Hz, the output has time to charge the capacitor before it changes polarity. At the higher frequency, the time constant exceeds the half-period and so the entire time is spent charging the capacitor, with the result that the voltage drops nearly to zero. \$\endgroup\$ – Scott Winder Oct 2 '13 at 14:38
    \$\begingroup\$ @ScottWinder - while Aug's circuit may be making the situation worse, please understand that this is an inherent property of this type of DDS, irrespective of loading. \$\endgroup\$ – Chris Stratton Oct 2 '13 at 14:48
    \$\begingroup\$ Aug - is your scope probe 1x? Try switching to 10x as that will reduce the loading capacitance Scott is talking about. I don't think the step vs impulse rolloff predicts the degree of difference you are seeing. \$\endgroup\$ – Chris Stratton Oct 2 '13 at 14:55
In addition to the normal attenuation at increasing frequencies (as @ChrisStratton and OP pointed out), there is the potential to unwittingly add a low-pass filter to the output by decoupling it. This is based on the fact that the trace (or wire) between the DDS output and the decoupling capacitor will have some resistance, which combines with the capacitor to form an RC filter. The cutoff frequency is defined as: $$ f_{c}=\frac{1}{2 \pi RC} $$ Taking an arbitrary trace resistance of \$60 m\Omega\$ (consistant with a ½ inch, 8 mil, 0.5 oz trace) with your 100nF capacitor, we get: $$ f_{c}=\frac{1}{2 \pi \cdot 0.06 \cdot 100n} \approx 26.5MHz $$ This will change based on the actual resistance, as well as the capacitance of the scope probe (as discussed by @ChrisStratton), but it shows that the capacitance could be having a very real effect on the output amplitude at higher frequencies.
| improve this answer | |
  • \$\begingroup\$ I never noticed the large impact of copper wire resistance. I reduced the distance between output and user part + reduced coupling capacitor to 50pF and also used 10x on oscilloscope. The amplitude is now as expected in the formula. \$\endgroup\$ – Aug Oct 2 '13 at 21:01
