I try to implement the following simple UART reciever. The simulations goes fine (image attached). But i encountered some problems in real hardware realiztion using Nexys 2 board. I try to send a symbol through minicom using the following protocol 1 start bit 8 data bits 1 stop bit 115200 baud rate Also i have 50 Mhz FPGA clock, which i directly use as UART reciever clk. UART counter count to 434 (F = 115200 Hz -> T = 8680 ns -> T = 20 ns * 434) So checking in 233 we will get the center of recieved bit. While debugging the output of the uart i attached DATA_OUT from reciever to the Nexys board leds.
It seems to me that i get the wrong symbol codes. For example when i send '1' (00110001) i get 10011001 code and so on
'2' 00110010 -> 10011010
'3' 00110011 -> 10011011
'4' 00110100 -> 10011000
So my suggestion is that something is wrong with the VHDL code, but i don't understand what exactly... Can anybody help me please? Thanks.
entity uart_reciever is
Port ( clk : in STD_LOGIC;
rx : in STD_LOGIC;
recieved : out std_logic;
en : in STD_LOGIC;
data_out : out STD_LOGIC_VECTOR (7 downto 0)
end uart_reciever;
architecture Behavioral of uart_reciever is
signal count : std_logic;
signal rec : std_logic := '0';
signal counter : integer range 0 to 433;
begin
process (clk)
variable state : integer range 0 to 9 := 0;
variable data : std_logic_vector (7 downto 0);
variable rx_p : std_logic;
begin
recieved <= rec;
if rising_edge(clk) AND en = '1' then
if (rx_p = '1' and rx = '0') then --
count <= '1';
rx_p := rx;
else
rx_p := rx;
end if;
if (counter = 216) then
rec <= '0';
case (state) is
when 0 =>
if (rx = '0') then -- -
state := 1;
else
state := 0;
count <= '0';
end if;
when 1 =>
data(0) := rx; --
state := 2;
when 2 =>
data(1) := rx;
state := 3;
when 3 =>
data(2) := rx;
state := 4;
when 4 =>
data(3) := rx;
state := 5;
when 5 =>
data(4) := rx;
state := 6;
when 6 =>
data(5) := rx;
state := 7;
when 7 =>
data(6) := rx;
state := 8;
when 8 =>
data(7) := rx;
state := 9;
when 9 =>
state := 0;
count <= '0';
if (rx = '1') then
data_out <= data;
rec <= '1';
end if;
end case;
end if;
end if;
end process;
process (clk)
begin
if rising_edge(clk) then
if (count = '1') AND (counter < 434) then
counter <= counter + 1;
else
counter <= 0;
end if;
end if;
end process;
