27
I compared 1N400x diodes here. As far as I see, all of their properties are same other than their maximum reverse voltages.
Their
  • maximum current
  • recovery time
  • reverse leakage current
  • capacitance
are the same.
It looks like 1N4007 is the super version of all other 1N400x diodes. So, why would one produce 1N4001...1N4006 diodes, and why would one buy them? If 1N4007 does the job alone, then why are the other versions still in the market?
5 Answers 5
23
The answers by @Vasiliy and @johnfound are incorrect. 1N400x diodes are not all identical except for "accidental" manufacturing variations.
Diodes with higher reverse voltage ratings are intentionally manufactured with lighter doping so that the depletion region for a given reverse voltage is wider than it otherwise would be. The disadvantage with lighter doping is that the forward resistance and voltage drop for a high-voltage diode is higher than it would be for a lower-voltage diode.
So, you can use a 1N4007 for all of your applications, but your circuit efficiency will be slightly higher if you use a more appropriately-rated diode in low-voltage applications.
    \$\begingroup\$ According the manufacturer specifications, the forward voltage drop is totally equal for all 1N400x diodes. \$\endgroup\$
    – johnfound
    Oct 6, 2013 at 11:24
    \$\begingroup\$ To my best knowledge, junction capacitance is very sensitive to depletion layer width. If it was really just the doping densities and depletion layer width, I'd expect junction capacitance to vary as \$\propto \frac {1}{V_B}\$. This is not consistent with the data provided by manufacturer, therefore I conclude that it it not just the doping densities which lead to wider depletion region which are responsible for different \$V_B\$. PN diodes can be much more complex than a simple 2D model demonstrated in all the theoretical examples... \$\endgroup\$
    – Vasiliy
    Oct 6, 2013 at 16:59
    \$\begingroup\$ ...Can you provide any reference for your answer? I can hardly believe that diode's manufacturers just throw away poorly performing diodes and do not try to sell them as a less tolerant device. \$\endgroup\$
    – Vasiliy
    Oct 6, 2013 at 17:03
    \$\begingroup\$ I recall seeing an increase in forward voltage in the 4007 over the 4001, about thirty years ago (unfortunately I no longer have the relevant data). It is possible that manufacture has changed and this is no longer true; I can't see any current evidence for it. \$\endgroup\$
    – user16324
    Oct 6, 2013 at 17:26
  • \$\begingroup\$ I think there is some binning going on, but that is not all. The 1n4007 diodes are a lot bulkier than the 1n4001 if I remember correctly ... \$\endgroup\$
    – jbord39
    Feb 1, 2017 at 4:38
12
There appears to be two fundamentally different types of diodes sold as 1N4001..1N4007. The first type is a conventional diode and is sold as 1N4001..1N4005. There is no disadvantage (except possibly price) in using 1N4005 diodes for everything. In my experience the price difference is very nominal or nonexistent in large quantities- for example in 100k price Digikey lists both at $11.20/k as of this writing.
The second type is a PIN construction and is used for 1N4006 and 1N4007.
1N4006-1N4007 have worse forward and reverse recovery time. They also have lower junction capacitance at all reverse bias voltages (eg. 10pF vs. 15pF at -10V). For actual curves illustrating the difference, refer to the Motorola Semiconductor Library databooks. For example:
For 50/60Hz rectification there is little substantial difference, and there is no difference in forward voltage at a given current.
In modern times we would likely use a different type of diode at higher frequencies (over a few kHz square wave or maybe 5kHz sine wave) so the differences are no longer that important, but a few folks have pushed the PIN types into RF service.
Due to process variations, manufactured semiconductor devices may have different characteristics. Many manufacturers employ "binning" strategy for manufactured parts: they test the parts and divide them between several "bins" based on devices' performance. Once they do this they can sell the better performing devices for more money.
I'm completely sure that binning strategy is employed for 1N400x, but I can't say how many pools were initially produced. My guess is 2 pools, from which 7 bins were derived. This guess is based on the fact that the data for Typical Junction Capacitance in the datasheet has two regions. Even if I'm right about this manufacturer, the number of pools can be manufacturer specific.
The difference between these diodes is mainly their reverse breakdown voltage. There are many more parameters which differ; part of the differences are mentioned in the datasheet (like the aforementioned junction capacitance), others are not. In general, x20 ratio in reverse breakdown voltages (between 1N4001 and 1N4007) reflects major differences in junctions' properties. These properties must affect almost any electrical parameter of the diode.
Manufacturers tend to represent these diodes as having exactly the same properties because the very fine differences are not important for main areas of employment of these diodes. There are applications which require more precision though.
People say that there are also applications which take advantage of diodes' reverse breakdown. In these applications you might want to be able to choose a suitable breakdown voltage. I don't know the specifics though.
My guess is that years ago, when these diodes were just introduced and the semiconductor processes were not mature, the differences between different diodes were more pronounce.
Summary:
If the price is the same and you use these diodes in "standard" applications (like low frequency rectification), you may use any of them as long as it satisfies your requirements for reverse breakdown voltage. If you are planning to use them for something more sensitive, you might want to test them all to see which one suites better.
    \$\begingroup\$ +1 for "semiconductor processes were not mature". One has to wonder if some parts are not even binned these days, but merely labelled as demand dictates, and propagated simply because they are foundational parts that will probably never go obsolete. \$\endgroup\$
    – Trevor_G
    Sep 6, 2017 at 14:52
  • \$\begingroup\$ @Trevor_G I know a chemical company that does that with their products. I asked them what the difference between two chemicals are and they said that it was just the same stuff in different labelled bottles for marketing purposes. \$\endgroup\$
    – DKNguyen
    May 28, 2020 at 22:04
I sure like the answer from Spehro Pefhany, but in today's datasheets- many do not mention any differences anymore... http://www.comchiptech.com/cms/UserFiles/QW-BG013%201N4001%20Thru456224.%201N4007%20REV.A.pdf
http://www.mccsemi.com/up_pdf/1N4001-1N4007(DO-41).pdf
http://www.vishay.com/docs/88504/1n4001gp.pdf
http://www.onsemi.com/pub/Collateral/1N4001-D.PDF
The Diodes Inc. original version has this difference, where the Junction Capacitance is worse for the lower voltage versions...
Diodes Datasheet Excerpt
But they are all 8pF in the new 1N400xG versions...
G Version
Seems there is no perceivable difference anymore, other than many BOM's have different versions spec'd in, so each MFR keeps offering every version.
These all are the same diode. The semiconductor technology is not so precise, so, the diodes, produced in one technological cycle are different. After sorting they are marked respectively. It is a common practice not only for diodes.
Additionally, sometimes (not very often) there are schematics where the diode works in avalanche breakdown mode, so you will need the breakdown voltage to be predictable.
