I'm designign a circuit using the AMC1200 isolation amplifier from TI.
http://www.ti.com/product/amc1200-q1
As you can see the output is differential, and I'd like too feed it to a schmidt trigger to catch the 2.5V transitions. The problem is that the trigger is single ended, so here is my question: is there an easy way to transform the fully differential output in a single ended output i.e. having the difference between the outputs? I know I can use just one of the outputs but I basically loose half of the dynamic range, and that might be a problem.
