Hey all I am fairly new with the MSP430 and I have begun using it to do very simple projects and I am trying to keep track of how many cycles I use within my program, and I have a two simple questions that I cannot find the answer for.
How many cycles does it take to run the 'ret' or 'reti' from my program? How many cycles does it take to assign a variable in MSP430 or to call the variable as seen in my "mov.w #COUNT,r13" as seen below? Here is the part of the code that I am using:
COUNT       .equ    <number>                ; <-- Does this take any cycles?
callLoop:   call    #myDelay                ; 2 cycles
            sub.w   #1,r12                  ; 1 cycles
              jne   callLoop                ; 2 cycles
            jmp     RESET                   ; 2 cycles
myDelay:    mov.w   #COUNT,r13              ; 1  <-- Is it only one cycle to run the mov.w?
delayloop:  sub.w   #1,r13                  ; 1 cycles
              jne   delayloop               ; 2 cycles
            ret                             ; ???  No idea what this would be.
r12 has already been assigned a value earlier. Let me know if you need anything else from me.
  • \$\begingroup\$ Hrm. I was thinking about looking into MSP430, but after a few minutes of researching the answer for this question, I think I'll hold off. \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 8 '13 at 4:20
  • \$\begingroup\$ lol, I feel like there's nowhere for me to find the basic information that I need. Anything that exists usually assumes that I already know what I'm doing, a pretty hefty assumption. \$\endgroup\$ – Mitch Oct 8 '13 at 4:26
  • \$\begingroup\$ Isn't Return simply a jump? But to a memory address held on the stack? \$\endgroup\$ – Passerby Oct 8 '13 at 4:34
  • \$\begingroup\$ The answer is actually somewhat convoluted. ret is actually mov.w @sp+,pc under the hood. \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 8 '13 at 4:36
  • \$\begingroup\$ So if its mov.w @sp+,pc then that means it is going to be 3 cycles because it is indexed and auto-increment from what I understand. Excellent, where did you find that answer Ignacio? \$\endgroup\$ – Mitch Oct 8 '13 at 4:43
According to this article, ret is actually mov.w @sp+,pc, so it only takes the cycles required for indirection, post-increment and assignment to the program counter.
.equ is an assembler directive similar to #define in C and generates no instructions; the mov.w #,r uses a constant substituted by the assembler and therefore incurs no additional cycles.
