I have a sn754410ne IC (quad half h-bridge). I noticed that whenever driving two motors, one motor is driven faster than the other (with both DC power and a PWM signal from my Arduino UNO). I measured the voltage across each motor and noticed there was a discrepancy of .015V. What can I do to drive the motors at the same speed, aside from sending a smaller PWM signal to the faster motor?
  • \$\begingroup\$ Did you try swapping the motors over to their counterpart drive circuit to see if the low speed followed was related to the driver or the motor. Do you have both motors driving similar mechanical loads? \$\endgroup\$
    Oct 9, 2013 at 7:35
  • \$\begingroup\$ Easiest way to run the motors at the same speed is to connect the shafts together. \$\endgroup\$
    – shuckc
    Oct 9, 2013 at 11:51
The reality is that your two "identical" motors are only approximately identical; there are always going to be minor manufacturing variations. If you want to run them both at a more accurate approximation of the same speed, you will need to provide feedback (of the motor speeds) to your controller so that it can adjust the drive PWM signals so that the speeds of the two motors match.
