WiFi module:     WIZ610WI
Microcontroller: LPC1788
Purpose:         Connect it via MII on PCB
I have the following scheme: MAC-to-MAC via MII scheme
  1. Do I need a signal delay on TX_CLK?
  2. On what line and what the value of the resistor to set?
  3. Are there guidelines for the design of such boards?
The image from: enter link description here
In "Errata sheet LPC1788":
3.4  ETHERNET.1: In Ethernet MII mode, the transmit data TXD3:0 and
transmit enable TX_EN incorrectly reference RX_CLK in data
transmission
Problem:
In MII mode, the transmit data TXD3:0 and transmit enable TX_EN should reference the
TX_CLK from the Ethernet PHY. However, due to a configuration error in the chip, the
transmit data TXD3:0 and transmit enable TX_EN reference RX_CLK in data
transmission. The consequence of this error is that a small percentage of packets cannot
be received by the PHY.
Work-around:
This will be fixed with the next silicon release.
Note: There is no issue in RMII mode operation.
If I gather the scheme, will it work normal?
