I have connected my pwm pin to my arduino like in this tutorial
http://fritzing.org/projects/reading-pc-fan-rpm-with-an-arduino/
It's working properly. I can read and set the speed using a sketch from this website:
http://www.beefrankly.org/blog/2011/12/21/read-out-4-pin-cpu-fan-speed/
int fanPulse = 0;
unsigned long pulseDuration;
void setup()
Serial.begin(9600);
pinMode(fanPulse, INPUT);
digitalWrite(fanPulse,HIGH);
void readPulse() {
pulseDuration = pulseIn(fanPulse, LOW);
double frequency = 1000000/pulseDuration;
Serial.print("pulse duration:");
Serial.println(pulseDuration);
Serial.print("time for full rev. (microsec.):");
Serial.println(pulseDuration*2);
Serial.print("freq. (Hz):");
Serial.println(frequency/2);
Serial.print("RPM:");
Serial.println(frequency/2*60);
void loop()
analogWrite(3,20);
delay(5000);
readPulse();
analogWrite(3,50);
delay(5000);
readPulse();
analogWrite(3,100);
delay(5000);
readPulse();
analogWrite(3,200);
delay(5000);
readPulse();
analogWrite(3,255);
delay(5000);
readPulse();
It seems to me, like I can only enter values higher than 127 and values lower than 127. There are no steps between them. The fan won't turn slower when I go from 126 to 0 or from 128 to 255.
Some results I get:
100:
 pulse duration:19058
time for full rev. (microsec.):38116
freq. (Hz):26.00
RPM:1560.00
0:
pulse duration:19160
time for full rev. (microsec.):38320
freq. (Hz):26.00
RPM:1560.00
127:
pulse duration:9032
time for full rev. (microsec.):18064
freq. (Hz):55.00
RPM:3300.00
255:
pulse duration:9151
time for full rev. (microsec.):18302
freq. (Hz):54.50
RPM:3270.00
Is there some mistake I've made or is it possible my fan won't accept precise values? Can you recommend any 4 wired fans I could use for this or some other way? I thought about using a SG2524N to controll a two wired motor, but I'm not experienced with this. Thanks for your advice.
  • \$\begingroup\$ Are you sure that pin 3 is a PWM channel on your Arduino? Use a LED to test. \$\endgroup\$ Oct 10, 2013 at 1:19
  • \$\begingroup\$ I'm now using SoftPWM, still no change. I'm going to switch the fan and try again \$\endgroup\$
    – Wolfen
    Oct 10, 2013 at 8:20
Fans don't use stock pwm frequencies. The PWM control frequency needs to be 25khz. A 16mhz arduino can do this relatively easily through software. Just search "4 wire fan arduino" and there's quite a few posts on it, including sample code to set the prescaler frequency so the output PWM is at 25khz.
