How are those connectors called?
http://www.keelog.com/images/kl_mod22.jpgenter image description here
  • \$\begingroup\$ @Andyaka How do you call those small plugs on around the wires on the second image \$\endgroup\$
    – user30289
    Oct 10, 2013 at 14:37
  • \$\begingroup\$ try molex's website - it's pretty clear info the first time I thought \$\endgroup\$
    Oct 10, 2013 at 14:39
It is a widely-used 4-pin female connector, a crimp housing with four female crimp terminals inserted. There are many manufacturers that make a connector like this, but Molex makes one Part Number: 50-57-9004 (SL™ Crimp Housing, Single Row, Version A, Non-polarized, 4 Circuits) in the SL Modular connector line. You can order this housing on Digi-Key.
You can easily crimp these terminals yourself with a low cost hand crimping tool if you want to make cable assemblies with this kind of connector. You'd need to buy a bag of female crimp terminals to use, then after crimping the wires, you insert the terminals into place in the housing.
  • \$\begingroup\$ don't forget the gold-plating \$\endgroup\$ Oct 10, 2013 at 16:41
  • \$\begingroup\$ Are you sure the 'Digi-Key' housing is the one in the pictures? \$\endgroup\$
    – user30289
    Oct 11, 2013 at 8:32
  • \$\begingroup\$ Since these connect to header pins, shouldn't these alos be properly referred to as "header connectors"? \$\endgroup\$
    – Shabab
    Oct 11, 2013 at 14:50
  • \$\begingroup\$ @Shabab it is a "header connector" when assembled, but the product consists of separately ordered parts: a crimp housing and the crimp terminals -- where the crimp terminals can be shared between many different types of connector form factors (different housings) \$\endgroup\$ Jan 29, 2014 at 0:10
  • \$\begingroup\$ @user30289 DigiKey is just the distributor, if that's not the connector you ask about you should specify it in the question \$\endgroup\$
    – clabacchio
    Sep 8, 2020 at 10:24
You'll find that Molex manufactures these connectors, part of their SL line - non-polarized housing, in particular. In my experience, however, they're far more commonly termed "DuPont connectors". (People more often relate latched connectors to Molex.) They are also colloquially referred to as "jumper connectors" or "pin header connectors" on occasion, which is a bit vague, but since 0.1" pitch is most common, the terms are more often than not in allusion to these guys.
Edit: Almost forgot, the proper name, I believe is "Mini-PV", originally produced by DuPont, hence "DuPont connector", even though they made others.
If you search for 4 pin Molex connector, you'll find what you are looking for. Molex isn't the proper name for it, but the company is like the Kleenex of connectors.
    \$\begingroup\$ I can't find those type of "Kleenex connectors", I can only find "Kleenex Ultra toilet roll" stuff... How do you call those small plugs on around the wires on the second image? \$\endgroup\$
    – user30289
    Oct 10, 2013 at 14:36
  • \$\begingroup\$ Make some effort and search in google it. \$\endgroup\$
    – Butzke
    Oct 10, 2013 at 14:47
  • \$\begingroup\$ they're crimp on , they're for square pins, they're ....gold plated...they're.....female header connectors.... they're 'female crimp pins' pololu.com/catalog/product/1930 \$\endgroup\$ Oct 10, 2013 at 15:32
  • \$\begingroup\$ That's the funniest comment I have ever read on this website. \$\endgroup\$
    – HL-SDK
    Oct 10, 2013 at 19:53
    \$\begingroup\$ 4-pin Molex, to me and any other computer enthusiasts, as the typical cable supplying +12V and +5V lines (along with two COM wires) to peripheral devices in ATX PSUs. \$\endgroup\$
    – Shamtam
    Oct 11, 2013 at 3:11
