I'm programming an ATtiny2313, with some hex for an infrared remote IgorPlug with AVR via USB, I'm new to AVR and need to confirm please that what he refers to the fuse configuration:
Q: Is possible to use ATtiny2313 instead AT90S2313?
A: The device is compiled for AT90S2313 but works also on ATtiny2313 - same HEX file (binary compatible). For correct operation on ATtiny2313 you must set fuses during programming: disable division the external clock by 4 and enable high speed XTALL.
So is this correct?
low: Oxff
High: 0xff
Extended: 0xff
I need to use a 12 MHz xtal
CKDIV8 must be 1 (unprogrammed), and CKSEL must be %1111. The rest of the fuse bits are application-dependent and you must read the datasheet in order to determine what they should be.
| improve this answer | |
There are numerous sites that provide fuse bit calculators for AVR, here is one: http://www.frank-zhao.com/fusecalc/fusecalc.php?chip=attiny2313
You'll have to check the datasheet (pg. 159) for their exact meaning, but when entering the calculator it pops up the default fuse settings for the device (64 df ff)
I would recommend to change only the fuses you need to change. According to http://www.engbedded.com/fusecalc the defaults are:
  • low: 0x64
  • high: 0xDF
  • ext: 0xFF
As said before you want to change CKDIV8, but you could also change this at runtime in software. The other bits you have to consider are SUT0 and SUT1 and CKSEL0 to CKSEL3. This depends on your circuit, so reading the manual is always a good idea. You see all these flags are in the low fuse. Leave the others ontouched. It is sufficient to set those fuses once, they will stay at this setting.
