I want to control the speed of a two-wire DC motor using PWM. I already managed to control a 4-wire motor, but now I need to use a two-wire motor.
I would connect it to the Arduino directly, but the pins won't provide enough mA current to control the motor properly.
Is there a good way to provide energy to the Arduino and the motor plus controlling the motor using PWM?
Specifications of my Motor:
  • Rated voltage: 1.3V
  • Rated current: 65mA max
  • Starting voltage: 0.75 V
  • Stall current: 170mA max
A switching buck regulator will just let you provide the correct voltage for the motor (many have a minimum output of 1V3). You should be able to power it off the same supply as the Arduino if enough current is available.
An H-bridge cross-connected to complementary PWM pins will allow you to control the speed and direction of the motor, with 50% duty cycle being no motion. Make sure to use a high enough PWM frequency that the motor doesn't vibrate when at the stop frequency.
use a motor shield, which have an external power socket. I have controlled 2 motors and 2 servos with one arduino board ... seems to work just fine. plus you should probably look into providing it with more amps as arduino only provides you with 40 mA
    \$\begingroup\$ I don't want to buy a motor shield because they are very expensive. I thought it would be cheaper to build it myself. I bought some L293D H Bridges. As you already said, I have to find a way to provide more than 40 mA to the motor. \$\endgroup\$
    – Wolfen
    Oct 19, 2013 at 17:21
