What is the difference between a 8 bit buffer and a 8 bit latch?
Are they both used for the same purpose?
The 74LS273, is a buffer or a latch?
With regards to low-level electronics, a buffer is a device whose output will always follow its input. A latch's output will follow its input only while the latch enable is active; when the enable goes inactive the latch will hold the last value it had.
At a high level, "buffer" simply means any sort of circuit that will sustain a previous value, and therefore the term has no place in any sort of discussion that requires enough precision to mention "latch".
Not at the low level.
Latches are level-enabled. The '273, being edge-enabled, is a flop-flop.
  • \$\begingroup\$ "Buffer" has two meanings. \$\endgroup\$ – travisbartley Oct 16 '13 at 4:05
    \$\begingroup\$ @trav1s: True. I had assumed that the OP meant from a low-level electronics perspective due to the subsequent use of "latch". \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 16 '13 at 4:07
  • \$\begingroup\$ WIkepedia says a buffer can store data temporarily.Now what would happen if the data is being replaced before it is read? does it mean that earlier data is forever lost? \$\endgroup\$ – DesirePRG Oct 16 '13 at 4:08
  • \$\begingroup\$ @DesirePRG: Please revise your further questions based on the edit to my answer. \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 16 '13 at 4:46
