-I am using cc2500 at target device and cc2511 at Host device.
-I want to transmit and receive data between this two device at 500 Kbps data rates.
-My X'tal freq for cc2500 is 27MHz and for cc2511 is 48 MHz.
-My base freq is 2410 MHz.
-I tried automatically generated register setting from smart RF studio but it's not working.
-I know that below register are affected for changing data rate .
MDMCFG4,MDMCFG3,,MDMCFG2,MDMCFG1,MDMCFG0,DEVIATN,FSCAL3,FSCAL2,FSCAL1,FSCAL0,PKTCTRL
-I tried as much as i possible but failed to communicate this two device.
help me to figure out this problem.
Does your hardware works with a lower data rate? Can you connect the two units with a coax cable and two 10dB attenuators (One on each unit) and verify a link at 500kbps? Do you get CRC or framing errors from the devices? Do you have a wifi network on channel 1, bluetooth tranceiver, other 2.4GHz devices near your units?
Edit: Did you check the crystals? They should be within 80ppm of each other. For 2 nodes with 27MHz crystals of the CC2500 it means a maximum of 200Hz difference between the 2 units. The CC25xx requires a maximum 40ppm error from its timing source (Crystal or oscillator). Try generating a CW signal and measure the difference with a spectrum analyzer.
To make measurement of the crystal easier, you can output its frequency/192 to GDO0.
  • \$\begingroup\$ :Yes,My hardware works with lower data rates.I want to simple connect this two chip for data transfer.At lower data rates there are no kind of error during communication. \$\endgroup\$ – shail korat Oct 16 '13 at 7:12
  • \$\begingroup\$ Next step in the debugging process then.. \$\endgroup\$ – Lior Bilia Oct 16 '13 at 10:06
