7
I just received my TI Launchpad and I'm wondering how can I add something like an Ethernet Shield from Arduino, in order to display a simple webpage... ?
Do you know any Ethernet shield for Launchpad?
    \$\begingroup\$ I don't think the msp430G22xx has enough memory or ram to be used as a web server, but I think some of the other msp430 chips can, I thought i saw an application note not too long ago, but could not find it recently \$\endgroup\$
    – jsolarski
    Jan 5, 2011 at 3:07
  • \$\begingroup\$ of course i'm not saying the MSP by it's self, with some PIC or Wiznet controler to do the hard work :D \$\endgroup\$
    – s.mihai
    Jan 5, 2011 at 12:39
  • \$\begingroup\$ I wish you luck, and if you succeed, let me know :) \$\endgroup\$
    – jsolarski
    Jan 6, 2011 at 14:09
The Arduino Ethernet shield is built around the Wiznet W5100. The chip provides a complete TCP/IP stack and can ethernet.
Porting the Arduino driver code to the Launchpad should be fairly straightforward, you'll need SPI and a few control lines.
http://code.google.com/p/arduino/source/browse/trunk/libraries/Ethernet/utility/w5100.cpp
Here's some Launchpad SPI code of mine to get you started:
http://blog.hodgepig.org/2010/09/10/575/
The Launchpad currently has no official shield standard though there are efforts afoot:
http://www.43oh.com/forum/viewtopic.php?f=19&t=16&start=10
http://www.msp430launchpad.com/2010/08/shield-standard-proposal.html
