I have an in-car charger left after I sold the GPS localizer. According to Wikipedia, it uses "UC-E6 proprietary (non-USB) plug" (second to the left on this photo).
Does anyone know any device, that uses the same plug. Or is there a DIY kit for assembling such a device? Or maybe someone heard about any adapter, that could be used with this charger and any standard microUSB device?
I'm trying to determine, if I can find any usage for this charger or if I should throw it away, since I got rid of the original device (GPS localizer),that used it.
  • \$\begingroup\$ You mean other than Nikon cameras? \$\endgroup\$ Oct 18, 2013 at 7:28
  • \$\begingroup\$ I didn't knew, Nikon uses it. But, yeap -- I was rather thinking about devices that can be more like used in car (since this is in-car charger, plugged directly to car's electrical system). Like a smartphone, tablet, GPS navigation, MP3 or video player, audio system, car's camera (recording as you drive) etc. Photo cameras are rather on the end of such list (unless you do a lot of photos in your car -- Google Street View? :]). I'm talking about constant usage (for which constant power supply would be reasonable) rather than just powering a weak battery in device like a photo camera. \$\endgroup\$
    – trejder
    Oct 18, 2013 at 7:33
    \$\begingroup\$ I haven't heard of an adapter but have you considered snipping the lead and attaching to something else? Micro USB connectors themselves can be a bit tricky to solder but maybe you have a surplus cable sitting around and you can splice / solder the wires together. \$\endgroup\$
    – PeterJ
    Oct 18, 2013 at 8:16
  • \$\begingroup\$ @PeterJ I've asked: "I'm trying to determine, if I can find any usage for this (...)". Your suggestion about using microUSB connector seems to be a fully qualified answer. So, please, consider reformulating your comment to an answer, so I can vote it up and accept it, bringing you some reps. \$\endgroup\$
    – trejder
    Oct 20, 2013 at 11:08
I haven't heard of an adapter but you could consider snipping the lead and attaching to something else. Micro USB connectors themselves can be a bit tricky to solder but maybe you have a surplus cable sitting around and you can splice / solder the wires together?
The following photo taken from Splicing DataBus cables for exterior weatherproof deployment illustrates. That same page also goes into additional detail about achieving a professional result. You may want to invest in some heatshrink tubing but alternatively electrical tape could be used for a "less neat" solution to insulate the wires.
Splicing cables together
I have a TI-84 Plus Silver Edition graphing calculator that appears to use that EC-U6 plug. Earlier this year my niece was here and none of our USB device-end connectors fit her camera, and now that I think about it, the port was similar to the EC-E6.
The TI-84 manual says "Communication Link: The TI-84 Plus has a USB port using a USB unit-to-unit cable to connect and communicate with another TI-84 Plus or TI-84 Plus Silver Edition. The TI-84 Plus also has an I/O port using an I/O unit-to-unit cable to communicate with a TI-84 Plus Silver Edition, a TI-84 Plus, a TI-83 Plus Silver Edition, a TI-83 Plus, a TI-83, a TI-82, a TI-73, CBL 2™, or a CBR™ System. With TI Connect™ software and a USB computer cable, you can also link the TI-84 Plus to a personal computer. As future software upgrades become available on the TI Web site, you can download the software to your PC and then use the TI Connect™ software and a USB computer cable to upgrade your TI-84 Plus."
It doesn't say anything about using the port for charging.
