Does anyone know the equation that relates current to voltage for a specific tunnel diode(can be any tunnel diode)?
I know these are old tech but I can't seem to find a relationship anywhere, all the info on tunnel diodes seems to be about the quantum mechanics involved.
7
Try looking for eg
tunnel diode transfer function
You are unlikely to get a single tidy expression due to the non linear nature of the beast and its "discontinuous" stable transfer function - which is what it's all about.
Some equations here near 1st diagrams.
The "magic" part is the negative resistance region - shown in red below.
Below is the classic Esaki diode / Tunnel diode transfer function and you can try to fit formulae to that if you think it useful. Unlike most other devices you cxan have the same current at 3 different voltages - with two being stable, and the intermediate voltage being a transient one due to it being in a region of negative resistance.
You could model this as something like y=x^3 with some offsets and shape adjustments but that would be missing the main point of the device.
Related:
Useful comment in [oscillator applications](http://www.powerguru.org/crystal-oscillator- design-and-negative-resistance/)
Here is a completely made up example. The formula is shown below the graph. This was made "by eye" solely on the basis of approximating an Esaki diode V/I curve. By adjusting parameters you could probably get a "close enough" fit to a real diode.
I doubt if this equation is especially useful but it does allow you to get a rough model of a real device. Axis units are semi arbitrary - adjust parameters to suit.
If you increase voltage above the maximum seen here you'll get a nasty shock due to the (5-Volts) term - no suggestion that this occurs in real life :-)
Off the Wall:
Plot an energy versus velocity curve for a mass approaching and exceeding light speed.
For mass use standard
M_relativistic = Rest_mass/(1- V^2/C^2)
Use Energy = 0.5 m x v^2.
Ignore (for now) complex-imaginary aspect for V>C.
eg assume for now that jE = E.
Plot energy against V. Wow!
Ponder.
-> You get a tunneling type curve with two velocities > C that have the same energy as a point for V < C for values of V only above a certain % of light speed. E goes to infinity at V=C as expected. BUT the curve is suggestive of a tunnel effect across C with two velocities > C with the same energy. There's more, but that's enough OTW already :-).
Implications of the tachyonic jE are, of course, unknown.
Take a look at this paper right here.
It gives some closed-form equations describing the tunnel diode total current density.Including the negative resistance region. Hope that helps.
One of the simplest, V-I characteristic curves for the (Esaki) tunnel diode is given by the following equation:
I= I(p)*(V(p)/V) exp (1-(V/ Vp)) + I(s)*exp(qV/KT)
Where Ip is the Peak current, I(s) the saturation current, Vp is the Peak voltage, V is the Applied voltage, q the charge, K is Boltzmann constant, and T is the Temperature. When V(p)=V(as in DC), the tunnel diode current becomes equal to the ideal diode equation.
The negative resistance is given by the equation:
R= -1/ [((V/V(p))-1) (I(p)/V(p))*exp (1-(V/V(p)))]
Hope this helps.
Source:MEPITS.com Tunnel Diode
