Today I got confused about Low pass filter transfer function. Let's assume we have a simple low pass RC filter . It is well known that at f=fc we expect -3dB (0.707) drop in Vin.
Everyone knows a LPF transfer function is:
On the other hand we know that :
Which results in :
If we set f=fc we will have:
But I expected 1/√2 =0.707 ! I am sure I am missing something but can not find that because this differs from the formula that I knew:
enter image description here.
  • \$\begingroup\$ Your result is correct if the input to the filter is \$e^{t/RC}\$, a real exponential. \$\endgroup\$ Commented Oct 26, 2013 at 16:07
The problem has come from the substitution of s for 2*PI*f.
s is a substitution for j*w
thus the equation actually is: 1/(1+j)
If you resolve this back to magnitude: 1+j = sqrt(1^2 + 1^2) = sqrt(2)
resulting in: 1/sqrt(2) = 0.707 as you expect
So take a low-pass filter: RC
$$ Vout = Vin*\frac{\frac{1}{j\omega C}}{R + \frac{1}{j\omega C}} $$ $$ Vout = Vin*\frac{1}{j\omega RC + 1} $$ $$ \frac{Vout}{Vin} = \frac{1}{j\omega RC + 1} $$ $$ \frac{Vout}{Vin} = \frac{1}{\sqrt{(\omega RC)^{2} + 1^{2}}} $$ From a magnitude point of view.
  • \$\begingroup\$ I thought s=jwf not j*w. Is that? \$\endgroup\$
    – Aug
    Commented Oct 26, 2013 at 14:09
    \$\begingroup\$ w (radians per second) is equal to 2*pi*f \$\endgroup\$
    – user16222
    Commented Oct 26, 2013 at 14:13
