I'm looking at this current sensor (datasheet)
I'm a little confused at this notation for hole size.
Datasheet drawing
Pin 5 and 6 have a diameter of 0.6mm while pin 1, 2, 3, 4 have a diameter of 0.25mm ? Is that correct ?
If someone could also explain what this format is "4-0.25x0.5". I've never seen this type of notation before.
Thanks!
edit
I think it could be 0.25mm x 0.5mm (length x width) since the pins look more rectangular vs circular for pins [1,4].
I think that diagram gives the pin sizes, not the recommended hole size. Pins 1 - 4 are 0.25mm x 0.5 mm. For the 3 amp version, pins 5 and 6 are 0.6 mm diameter.
The drawing below the one you show above shows pins 1 - 4 as small rectangles.
It seems that pins 5 & 6 are made of round wire. Diameter depends on the specific sub-model. The sub-models for greater current have thicker pins.
(There are also 40A, 50A, 60A sub-models, which have a stamped copper conductor. The drawing for those sub-models, is on the left side of p.2.)
Pins 1-4 are rectangular (flat, stamped). Thickness 0.25mm, width 0.5mm, length 5mm. The nominal hole diameter is the length of the diagonal of the cross-section of the pin. \$ \sqrt { 0.25^2 + 0.5^2} \approx 0.56\$ mm. Add an allowance. I would use a hole with finished diameter 0.81mm (or more).
