I am doing an experiment to build and test a 4-bit Digital to Analog Converter based on an R/2R ladder network. I build the DAC that looks like based on this schematic:
This circuit was hooked up to the counter chip and function generator which was set to generate square wave and 10 kHz frequency. Then I connected the DAC to an oscilloscope to test the result. The oscilloscope shows a staircase shape. As I increase the clock frequency, the edge of the stair steps becomes rounded and no longer reaches the 0 volt line on the oscilloscope (why does it no longer reach 0 volt line?) and the DAC becomes unusable, why?
