In a basic switching step-down LM2675 voltage regulator design (as shown in the picture from the datasheet below), what could possibly be the main cause of a short-circuited diode failure (D1 in the picture)?
A little background:
The company I am working for designed a special power supply as part of a larger product a few years back, that accepts 24V as input and uses an LM2675 to produce 5V output. The type of the diode is MBRS340 (Shottky, 3A, 40V).
Some devices (with these power supply units) have been returned by the customer and all units have the same fault: All Shottky diodes are short-circuited.
Additional to the circuit in the picture there is also a poly fuse to limit the output current to 0.9A, so a secondary short-circuit should not destroy the diode. Usually the output load is less than 100 mA.
The strange thing is that the rest of the circuit (on the 5V part) does not get damaged, so it remains working after replacing the faulty diodes.
The waveform across working diodes looks like this while the input voltage is 24V, so no unusual high voltage spikes visible.
Waveform:
Waveform zoomed in:
Do you have any experience with these kind of faults?
