I've used "touch lamps", where you turn it on and off by touching the lamp. As I understand it, this works by putting a small electrical voltage through the human body: touching the lamp completes the circuit, allowing electricity to flow from the lamp to the ground. Is this safe? What makes it safe? Is it because it is using very low voltage? Do they have special circuitry to protect people?
\$\begingroup\$ Also, Of course they are safe. Otherwise the lamps, and the touch kits to convert lamps, wouldn't be sold at retail stores. \$\endgroup\$– PasserbyOct 31, 2013 at 1:11
\$\begingroup\$ Just an older memory of same principle re electricity: Volts - Jolts Mills (amps) Kills \$\endgroup\$– LarryJan 13, 2021 at 21:40
\$\begingroup\$ @ElliotAlderson Sadly (IMHO) the system does not allow newcomers to comment so they must either remain mute or post an "answer". \$\endgroup\$– Russell McMahon ♦Jan 13, 2021 at 22:07
Your understanding of the way these lamps work is not quite correct. The lamps are basically capacitive touch sensors. Similar to a low, very low, resolution touch screen for a smart phone.
The idea is you're a capacitor. The lamp's surface is also a capacitor. The lamp knows how long it takes to charge itself. If you touch the lamp, you add to its capacitance and it takes longer to charge, the lamp detects this time difference and turns on.
It's perfectly safe. It's safe because the current is incredibly low. Voltage stings, current kills.
Don't you love lamp? I love lamp.
There are a couple of different techniques that can be used. One of them is the capacitive sensing technique as the touch screen on the iphone and other smart phones. Basically, the circuit in the device generates a high frequency (KHz range) signal that it applies to a capacitive sensing contact. When an electrically conductive object comes near the pad, some of the signal is capacitively coupled away. The sensing circuit detects this and uses the signal to turn the light on.
The second method is to use a very high gain amplifier (might just be a couple of transistors) connected to a sensing pad via a very large resistor (meg ohms). Your body acts like an antenna, picking up the 60 Hz line frequency in the wires in the wall. If you touch the sensing pad (or even just get close to it) a sensitive enough amplifier will be able to pick up this 60 Hz oscillation and then use that to turn on the lamp. Either way, we're talking very small signals here, on the order of milivolts and microamps.
Both of these methods are completely safe if implemented correctly.
I have owned a touch-control lamp for years. Depending upon the measurement device, the lamp base generates between 2-3.7 milligauss field at 16 inches. At 8 inches, the magnetic field was measured at 7.5-16 milligauss. Instruments: Approx 10 yr old Trifield(R) Meter Model 100XE. No calibration, and a new Poniie PN8000 multi EMF meter. As a professional industrial hygienist I consider these values unacceptable--at least until I can get a more precise gaussmeter. (I unplugged that lamp.) While there are currently no OSHA or EPA threshold limit values on 60 Hz fluctuating magnetic fields, I think it would be a good idea if manufacturers of touch-control lamps and wireless charging stations include EM radiation values with their products.
1\$\begingroup\$ Oppinionated answer with no scientific evidence \$\endgroup\$– kruemiMay 1 at 9:26
