I came across this image of an induction
Does anyone have any idea, on how to select the big Coil in the middle, and where can I buy it.
Those coils are almost certainly custom made for the device. It's probably made out of Litz wire as well for efficiency.
I'm not sure if anybody sells just the coil. However, it's just a flat wound air core coil, so it would be very easy to wind yourself if you can get your hands on some rather hefty litz wire. Of course you don't have to use litz wire, all that does is decrease the skin effect at high frequencies so the coil is less lossy.
| improve this answer | |
