I have a problem with running ENC28J60 with Arduino with EtherCard.h. This is the device I use: http://img20.allegroimg.pl/photos/oryginal/36/70/08/91/3670089168 This is the library and examples: https://github.com/jcw/ethercard I use Arduino IDE 1.5.4 on Windows. The library and skeches compiled without any errors. I tried connecting ENC28J60 to Arduino MEGA 2560 this way: GND GND VCC 3.3V SO Pin50 SI Pin51 SCK Pin52 CS Pin53
The LEDs on the RJ45 were active (green on, yellow blinking), but example DHCP or static IP failed or showed IP 0.0.0.0. Router detected the new device but the device did not responded to pings. I tried the modified example with modified line:
if (ether.begin(sizeof Ethernet::buffer, mymac, 53) == 0) Serial.println( "Failed to access Ethernet controller");
Where pin 53 is specified in ether.begin() function - with the same result. Then I tried connecting ENC28J60 to Arduino Nano this way:
VCC 3.3v GND GND SCK Pin 13 SO Pin 12 SI Pin 11 CS Pin 8
But then the LEDs on RJ45 blinked during connecting ethernet wire, and went dark. The red LED on ENC28J60 was on during above experiments.
I would apprieciate any help. I found many projects with google were people use ENC28J60 + Arduino Mega/Nano without a problem. I think that the EtherCard library version may not work with the latest Arduino IDE I have but then I don't know what version should I use, or maybe should I use some other library.
I need the ethernet controller for serving simple web page allowing changing the state of relay ON/OFF.
Some update:
After some debugging I can see that the code hangs in this line:
while (!readOp(ENC28J60_READ_CTRL_REG, ESTAT) & ESTAT_CLKRDY)
in enc28j60.cpp file. I suspect that I have faulty enc28j60 module.
