I have Arduino Uno R3 and Arduino Ethernet Shield V5.
What's missing in order to control 6+ lights (bulbs) from my home? Those are connected to 220V AC.
My idea is to send a packet via ethernet that has an order for example: "Turn on light 1", "Turn on light 4".
Maybe a relays module?
Obviously the power cables for lights will come from the controller. I want to test now so I can deploy it in real house lights.
Sorry if I am not being too much specific, I am starting to learn.
  • \$\begingroup\$ You'll want to search for a "relay shield" or "relay board". And be careful, mains voltage can be very dangerous. \$\endgroup\$
    – David
    Nov 1, 2013 at 18:10
  • \$\begingroup\$ "power cables for lights will come from the controller" No, the power for the lights will NOT come from the Arduino. The Arduino will send a small signal to a relay that will power the lights. \$\endgroup\$
    – mikeY
    Nov 1, 2013 at 19:32
  • \$\begingroup\$ @mikeY yes, that's true. Is this OK? articulo.mercadolibre.com.ar/… \$\endgroup\$
    – JorgeeFG
    Nov 1, 2013 at 20:05
Yes exactly. $10 or $15 US.
http://www.amazon.com/SainSmart-8-CH-8-Channel-Relay-Module/dp/B0057OC5WK
http://www.ebay.com/itm/8-Channel-5V-Relay-Module-Board-Shield-for-Arduino-PIC-AVR-MCU-DSP-ARM-/390594938127
