Hey so I'm trying to create a circuit on perf board that allows me to program three different types of chips using an Arduino Duemilanove as ISP. Those chips are the ATtiny85, ATtiny84, and ATMega328.
I want to use one 28-pin ZIF socket for all 3 chips, and not have to remember a specific placement for the chip, so I just want each chip to sit at the very top of the ZIF socket for the 8-pin 85 and 14-pin 84.
So I've mapped out all the connections that will need to go into the ZIF socket, and now have come across a switching problem.
Essentially there will be 3 states, one for each type of chip, and there are 6 signals that need to be switched (5V, GND, RST, MOSI, MISO, and SCK).
I've mapped out which pins each signal will need to go to, but now I need an analog switch IC or analog multiplexer to make this happen.
For example, MOSI looks like this:
State 1: MOSI -> 25 State 2: MOSI -> 7 State 3: MOSI -> 17
Since I have 6 signals, and 3 states, ideally a 6 channel 1:3 Demux would be perfect, but I think it's pretty certain those don't exist. It seems like the most practical I can find so far is a dual channel 1:4 demux, so I would need to use 3 of those.
Essentially what I'm here for is 1) Does anybody know of a better way to do this, or 2) Does anybody know of any IC's that can solve this?
