I have an RGB LED (datasheet here) that I want to control using an Arduino R3 (datasheet here). How can I do this? The LED has a common anode, not a common cathode. However, the arduino's I/O pins can only be +5 volts. This is a problem, because I need to somehow hook up the LED's cathodes to the arduino's I/O pins.
This is only a problem if you think in terms of SOURCING a current from an output. Outputs also SINK current.
When the output is set LOW current will flow INTO the pin to ground (SINKING).
The Arduino IO pins can "output" high or low (+5v or 0v) which means you can drive a LED either direction. Generic schematic (couldn't find RGB LED in the editor):
