In digital circuits (combination & Sequential) which input holds more priority clock signal or a reset signal? suppose we give a input reset in an asynchronous counter then reset will wait for clock signal or it will immediately reset the count?
An asynchronous reset will always be performed regardless of the state of the clock; a synchronous reset on the other hand requires a clock pulse before it will take effect. Most reset inputs on counters are asynchronous, but confirm this with the datasheet before assuming anything.
