I have a simple project that basically sends and receives data through USB connection and Bluetooth. Both the USB module and the BT module share the same UART RX (P1.2) and TX (P1.1) ports.
The problem I am having is that when the bluetooth is powered, I can't send commands to the MSP430 with the USB module. If I unplug the BT module, I can send just fine over USB.
Am I connecting them incorrectly, or do I need to disable the BT when using USB?
The USB module is based on FT232R: https://www.sparkfun.com/products/9716
The BT module is based on RN-42: https://www.sparkfun.com/products/10269
USB connections:
- GND --> GND
- CTS --> GND
- 3V3 --> N/C
- TXD --> P1.1
- RXD --> P1.2
- DTR --> N/C
BT connections:
- CTS-I --> N/C
- VCC --> 3.3V
- GND --> GND
- TX-D --> P1.1
- RX-I --> P1.2
- RTS-D --> N/C
