I'm trying to teach myself electronics from an old textbook, "Fundamentals of Electric Circuits", \$4\$th Edition, by Alexander and Sadiku. On page \$41\$, I can't figure out how they did example \$2.6.\$ See this diagram:
So I'm applying KVL around the loop. I get:$$-12 + 4i + 2v_0 - 4 - 6i = 0$$
But the book says it's \${+6i}\$. The current is flowing to the negative pole of the resistor, so it should be negative, right? Is the book wrong, or am I misunderstanding something?
Edit:
The book text for the problem reads:
Determine \$v_0\$ and \$i\$ in the circuit.
Solution:
We apply KVL around the loop as shown in the figure. The result is:\$-12 + 4i + 2v_0 - 4 + 6i = 0\$Applying Ohm's Law to the 6 Ohm resistor gives:
\$v_0 = -6i\$Substituting the previous equation into the first one yields: \$i = -8 A\$ and \$v_0 = 48 V\$
The way the book described to do this was to follow the current, and the sign of each voltage element is determined by the polarity. So \$-12 V, 4i\$, and so on. But continuing that pattern, we get to the \$-\$ pole of the \$6\$ Ohms resister before we get to the positive pole, so \$v_0\$ equals \$-6i V\$.
I'm not understanding something.
+6i
." Which value should be+6i
, and in which units? Is it Vo that is sought? [I don't have this book, as you can tell.] \$\endgroup\$ – Nick Alexeev Nov 9 '13 at 1:42
