12
High speed comparators are rather expensive and speed is what FPGAs are very good at. On the other hand, FPGAs (in my case: XC3S400) have paired differential pins in each bank that their voltages are compared ( At least I think so !). They also have Vref for single ended standards that may act as a comparator.
I want to know if I can use those differential I/O pair pins as a comparator -and if so- how should I do that ( Should I connect a vref and use single ended standards or simply connect two voltages to differential I/O pins ?)
EDITION: I tried it and works excellent !!!
  • \$\begingroup\$ If you stay within the documented voltage limits it ought to work after a fashion - precision may be more like 50-100mv than 1mv. How precise do you need? \$\endgroup\$
    – user16324
    Nov 10, 2013 at 11:24
  • \$\begingroup\$ @BrianDrummond precision is not a big concern, just converting a sine wave to logic level square wave. \$\endgroup\$
    – Aug
    Nov 10, 2013 at 12:56
    \$\begingroup\$ @Aug, that is how all the ADCs in the world work! \$\endgroup\$
    – FarhadA
    Nov 11, 2013 at 15:10
Yes you can. There are some applications notes using the differential pairs inside an FPGA as a low cost ADC.
There is a very good document describing this that you can use for your design:
Analysis on Digital Implementation of Sigma-Delta ADC with Passive Analog Components
  • \$\begingroup\$ the link does not work for me, do you have an alternative? \$\endgroup\$
    – David
    Nov 10, 2013 at 21:41
    \$\begingroup\$ Thank you for your guidance! I tried it and works nice. Now I have a very high speed comparator at no more cost ! \$\endgroup\$
    – Aug
    Nov 20, 2013 at 14:02
  • \$\begingroup\$ Glad it worked, I used it long time ago and was surprised how easy it was to implement a simple ADC inside the FPGA without any active components. I saved a lot of time and money doing so :) \$\endgroup\$
    – FarhadA
    Nov 20, 2013 at 21:36
    \$\begingroup\$ That is total BS Jon, I have been using it for over a decade. Just becasue a smart ass decided to patent it does not mean it is their design, I can show you at least 3 industrial application on the market for the past 10 years or so that uses this simple ADC idea. \$\endgroup\$
    – FarhadA
    Mar 30, 2016 at 7:16
