This is the hybrid-pi model of an n-channel JFET.
An answer on here claimed that the only difference between p-channel and n-channel JFETs is that voltages are reversed. How would this apply to the hybrid-pi model?
I would guess that the model would be identical to the one above except for changing the sign on \$v_{gs}\$, so that the source is positive, gate is negative, and current flows from source to drain. But I don't have sufficient understanding to know if this is correct. Is it?
If so, what about the h-parameter model for bipolar transistors? What would differ between N-channel and P-channel?
The claim for that answer is true. You should remember that the hybrid-pi, T or h models are small signal equivalent models where the small signal parameters are derivatives of the large signal model at a specific operating point. Since the derivative is a linear operator, the small signal model will encounter the same effect, of reversing the subscripts, or just negating the voltages.
You could simply modify the hybrid-pi model of the N-channel JFET as follows:
You should note that this circuit would have been the exact equivalent to the model you provided if I swap \$ v_{sg} \$ with \$ -v_{gs} \$.
| improve this answer | |
