I am trying to chose the parallel capacitors for the crystal on my micro-controller. The crystal is a 9.6MHz quartz crystal (chosen because 9.6MHz is good for UART communication). Going through the equations I get a value of 32.29pF. This seems higher than what I typically see on boards. This value is also higher than the 15pF recommended value in the Clock App note (image below). Can someone explain to me if I am doing the calculations correct?
MCU = ATXMEGA128A1U
MCU Clock App Note = here
Crystal = 407F35E009M6000
From application documents for the micro controller I get these numbers and equation:
Ce = 2CL - Ci - Cs
where:
Ce - is the external capacitance needed
Ci - is the pin capacitance
CL - is the load capacitance specified by the crystal vendor
Cs - is the total stray capacitance
ATxmega128A1 IBIS file (typical values):
C_comp = 4.44 pF
C_pkg = 0.27 pF
Ci = C_comp + C_pkg
Ci = 4.71 pF
Cs = ~3pF (typical of board traces)
CL = 20pF (specified for crystal).
Using that equation and Ce works out to 2*20 - 4.71 - 3 = 32.29pF.
