What is the signature of ATmega32A PU? I couldn't find it in the datasheet or Atmel's site. Is it same as ATMEGA32?
Page 250 (section 26.3) of the full ATmega32A datasheet:
datasheet exceprt
The "PU" designation is a suffix for ordering purposes, detailed on page 320. The "PU" just refers to the 40P6 package, which in turn is a 40-pin through hole version.
If you compare the ATmega32A to the ATmega32 (without the "A"), the signature is the same. The "A" revision is a replacement version with power consumption optimizations. Atmel has a guide specifically for migrating from the ATmega32 to the ATmega32A.
