Its required to find \$v_o\$. The question should be easy but I am not getting the same answer as offered by the textbook which is 2cos(400t-53). I am getting 5cos(400t-53). I tried doing in two ways: 1)reflecting the right impedance to the left and then converting the votlage back to the right circuit, 2) Using KVL and ideal transformers equation. I will show the latter here.
\$\frac{V_1}{V_2}=\frac{N_1}{N_2}=2\$. So, \$V_0=0.5V_1\$ But, we also know that \$I_2=2I_1\$. And that \$V_0=5I_2\$ where \$I_2\$ is the clockwise current in the secondary circuit. This implies that \$V_1=20I_1\$ (Eq 1) Using KVL, in circuit 1: \$-25\angle0 +40jI_1+10I_1+V_1=0\$ (Eq 2) Putting Eq 1 in Eq 2, and calculating \$I_1\$, we can then find \$V_1\$(using eq 1) and then \$V_0\$ which is half of \$V_1\$.
Have I done a mistake or is the answer in the book wrong?
