I have this headset which I use with a cordless handset. The problem is the volume is way too loud even if I turn it down all the way on the cordless handset. There are no controls on the headset. I really like this headset, it's just too loud. I wish there was a volume control on it. How can I make this happen?
Equipment list: Uniden Phone – model D3580 (standard 2.5 mm telephone headset) Plantronics headset which uses the standard 2.5 mm telephone headset
I assume I could buy a volume control (Potentiometer) but I don't know which one. How do I match it up to the specs? Remember, I only want to turn this down I don't need to make it louder so no amplification is needed.
What parts do I need exactly? How should this he assembled? Is it required I use a soldering iron or can this be done another way I'm not aware of? Thanks!
I'm assuming you will use (or want to use) this headset exclusively with the cordless handset so it isn't a problem modifying it.
If you can get to the speaker terminals then try putting a 100 ohm resistor in series with each speaker. This should attenuate things a bit. If still too loud then try a 330 ohm resistor, Hey they're 3 pence each (at most) so experiment a bit.
If potentiometers are your ultimate aim then experimenting with the resistors will get you an approximate value for a pot ohm wise. Without the little experiment you might be needing a ten ohm pot or a 1k ohm pot.
You ought to consider soldering this modification.
Andy's answer is a good one, but I would go for the opposite approach of starting with something oversized like a 10k pot in series with the speaker (assuming a one-earcup headset with one speaker - you'll need two potentiometers for two speakers) and adjusting until you're at a level you're happy with. At that point, you can use a digital multimeter to measure the resistance the pot is set to and decide if you want to replace it with something at a smaller range to give you better "resolution" around your target loudness, or with discrete resistors to make it permanent.
Audio pots sometimes have a "log taper" instead of a normal "linear taper", meaning that the resistance changes logarithmically as you adjust the dial. This has something to do with mimicking the way the ear interprets relative audio volume, where a log taper pot will appear to have a linear effect on perceived volume. This may or may not be of interest to you to consider for your application.
