I am trying to figure out the bandwidth of \$f_1f_2\$, where \$f_1 = sinc^2(3t)\$ and \$f_2 = sin(100t)\$. So when I take the Fourier Transform, I can rewrite the equation as such: \$F(\omega) \leftrightarrow F_1 * F_2\$. Easy so far.
Moving on, \$F_1 = 3\pi\Delta(\omega/12)\$, and \$F_2 = j\pi\delta(\omega+100) - j\pi\delta(\omega-100)\$. This is where I get stuck.
When you convolve anything with \$\delta(t+\tau)\$, it is merely placing the function you are convolving \$\delta(t+\tau)\$ with at time \$\tau\$. When taking bandwidths of frequencies, I know you only look past time \$t=0\$.
At this point I need to find the bandwidth of the function \$-3j\pi\Delta(\frac{w-100}{12})\$. Without this being in the imaginary frequency domain, for \$\omega \geq 0\$ there would be no bandwidth (everything is zero or has a negative amplitude for that frequency). However, we are in the imaginary frequency domain, so what would the bandwidth of this filter be?
The graph of the transform is
fourier transform [sinc^2(3t)sin(100t)]
(also on wolfram-alpha)
